ID a Cylinder Head - 67/68 911S?
The 2.0 Engine I just bought for the case came with a set of heads from a different year. The specs are:
Cast # 901.104.305.02 Date Code 9-66 Intake Valve: 42mm Intake Port: 36mm Exhaust Valve: 38mm Exhaust Port: 33mm I was thinking these are 1967 911 S heads, but from my research the exhaust port should be 35mm. Looking in Andersons engine book, I see that 1969 S enignes had 35 OR 33mm exhaust ports - could the 67/68 engines have the same variety? Any other thoughts as to what these heads could be? Regards, Andrew M
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car Last edited by andrew15; 01-17-2006 at 08:28 PM.. |
Anyone know?
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Regards mike 1983 911 SC sport, 1982 mini city |
Thanks Mike - I looked at the site and the legal Porsche parts CD and couldn't find a match. I think they list the parts as being for the whole head assembly.
Also, I'm not really sure if the 901.104.305.02 is an actual part # or a casting # Thanks, Andrew M
