-   -   gasket upgrades 3.0l sc (http://forums.pelicanparts.com/911-engine-rebuilding-forum/261566-gasket-upgrades-3-0l-sc.html)
Stein 01-17-2006 09:13 PM
What kind of kind of Gaskets whould you recomend for my 3.0l sc turbocharged? are the head gaskets simular to 3l turbo? other gaskets that i could use? any links where I can by sylider\crankcase shims 1-1,5mm?
Other upgrades that I should think about? 993tt cylinder head studs\arp? ++++??
Stein 01-21-2006 12:43 AM
Nobody want to coment??
what about cylinder head sealing on sc? are they good for turbocharging or should I use copper rings?
will be thankful for all possible upgrades i can make to my 3.0l sc for more HP......
cnavarro 01-21-2006 06:17 AM
That's a tough call. I'm assuming that your cylinders are stock? Alusil or nikasil? What amount of boost? I can't comment on the functionality of the original sealing ring on the SC and it's performance with the turbo, but a set of ARP head studs would be a great option, since you asked. If you want to go with a larger bore to get you to a 3.2, you'll want to just go for new cylinders, which leaves you with a plethora of sealing options.
Stein 01-21-2006 10:14 PM
Don't know if i have nikaslil or alusil but if I have alusil I'll go for 3,2 big bore's. Boost:high as possible... :-) I whant's tips how to make the engine compatible with higher boost\hp... head gasket's. studs, bearings, camshaft, valves, valvespring etc. etc... and for how mutch boost\hp eatch mod's will do...
f. eks; head gasked 3l sc - good for 1 bar boost
orginal studs - up to 0.5 boost...?
993 studs - up to 1 bar boost??
