adomakin's Avatar
camshaft housings-which is which?
just about to get the left side of my 930 bolted up when i read in waynes book that the cam housings are 'slightly' different. hmm... i just grabbed one of them and cleaned it up, thinking they were the same. hmm.... does anyone know the 'slight' differences?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 01-23-2006, 03:17 PM
resident samsquamch
sand_man's Avatar
If this is a 930 engine, the way I can tell is that the driver's side (cylinders 1 through 3) the cam housing is open on the rear (the portion that the actually receives the camshaft) to accomodate the scavenge pump. The pump is run off of the cam and therefore this section needs to be open on the housing. On cylinders 4 through 6 there is a large cover (more like a plug) that hides the back of the cam.
-jeff
Old 01-23-2006, 04:06 PM
adomakin's Avatar
problem is that both my cam housings are open at the rear! im building this 930 engine from scratch and this is what i have managed to get together.
Andy
Old 01-24-2006, 12:09 AM
Hello Andy.
They are the same as far as I know..never bothered to hand them!
Kind regards
Old 01-24-2006, 03:52 AM
adomakin's Avatar
hmm... so what is wayne talking about when he mentions subtle differences?
Andy
Old 01-24-2006, 07:33 AM
1972_911T's Avatar
Pet only lists one part no: x 2 so there must be the same.
Old 01-24-2006, 10:50 AM
adomakin's Avatar
good point steve.
by the way, im not too far away from doing the final timing on the engine so ill be able to let you know about my results soon.
Andy
Andy
Old 01-24-2006, 11:07 AM
resident samsquamch
sand_man's Avatar
I've got Wayne's book with me at the office (I bring it where ever I go) and after skimming through it, I didn't see any mention of the cam tower/cam housing/cam deck differences. However the differences between the right and left CAMSHAFT is mentioned. Could this be what you're thinking of?
-jeff
Old 01-24-2006, 11:08 AM
adomakin's Avatar
ill have a look in the book-maybe im reading something wrong but im pretty sure he mentioned something about 'subtle differences' somewhere near the middle of chapter 5
Andy
Old 01-24-2006, 11:13 AM
Yeah, I read that too. I scribed mine when I took it apart. Unfortunately, mine is a 911SC so I can't tell you what how they might be different for a 930.
-Brian
Old 01-24-2006, 12:25 PM
