-   -   head gaskets? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/262331-head-gaskets.html)
Ken911 01-22-2006 12:55 PM
head gaskets?
OK do I put any sealant on the heads? I have a 3.3 turbo and there are no head gaskets so do I use the curel sealant on the heads or just bolt em down?
DonE 01-22-2006 04:06 PM
Assuming you checked the mating surfaces (or at least had a machine shop check), you simply bolt them together.
