| code7rpd |
01-31-2006 05:18 PM |
Cam Timing Question
I just did the cam timing on my 3.2 ss with sport cams. The cams were suppossed to be timed at 1.4 to 1.7 and I got them timed to 1.6 on one side and 1.65 on the other side. I just wanted to confirm that these values should be attained once you get to Z1 after rotating the crank 360 degrees. If I go past 160 degrees the dial indicator continues past the set values. Is that normal? This sounds confusing so in essence, is I keep turning the cranshaft past 360, will the dial gauge continue to move past the 1.6 or 1.65 I set the cam to?
