-   -   Converting 2.4 to 2.3 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/264362-converting-2-4-2-3-a.html)
obrut 02-02-2006 04:57 PM
Is it possible/advisable to bore stock 84mm 2.4 cylinders out to 85mm in order to use them in a 2.3 short stroke motor?
(66 x 85 is required by rules of historic race series)
Also, could the 2.4 heads be used with the 85mm cylinders?
My starting point is a 2.4E (possibly 2.4S - haven't looked inside) spec motor.
Eagledriver 02-02-2006 07:34 PM
you would be basically doing a .020 inch overbore (.5mm off the walls). That should be ok. The problem will be finding pistons to match.
-Andy
obrut 02-02-2006 07:41 PM
thanks andy - quite a few places sell 85mm pistons EBS etc
Eagledriver 02-02-2006 09:11 PM
My Haynes manual shows a second oversize bore is up to 84.53mm. You'd be going bigger than that but not by much. I assume these are Biral cylinders? Just take a look at them and see how much iron will be left after the overbore.
-Andy
