-   -   Oil pump price ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/264621-oil-pump-price.html)
bavaria911 02-04-2006 03:11 AM
Oil pump price ?
Gents,
I have obtained a GT3RS (996) oil pump and would like to know the value of the pump. It is from a motor that only had 8,000 Kms. Motor was torn down to part out, car was in a reck. It is absolutely in perfect order w/o any wear marks on the inside gears or shafts. I will be tearing my 2.4 motor down and either machine my case to fit this pump or sell it and use the money for other areas needing attention.
Just looking for a value and make me an offer if you must :)
Vr,
Bavaria
davidppp 02-04-2006 05:49 AM
pump.
hello there.
I'd give 350 for this if you want to sell.
kind regards
david
bavaria911 02-04-2006 11:43 AM
My min price is $450.
Thanks,
Bavaria911
Jeff Alton 02-04-2006 11:45 AM
Well, then I guess you answered your own question, it is worth 450! :)
Cheers
bavaria911 02-04-2006 11:50 AM
Yup!
I sure did. I'll sell the pump to someone and they can save $300.
I'll call Henry...(or Henry can read this post) and ask what the machine work is and the cost to install the pump into a 2.4 case. Yes, I know it's an over kill, but since I have it....
Thanks,
Bavaria911
Jeff Alton 02-04-2006 11:55 AM
I agree, if you have it, may as well use it!
Cheers
BReyes 02-04-2006 04:33 PM
Let us know what you find out about fitting it.
Good Luck!
MBruns 02-05-2006 07:28 PM
Pump fitment
We have installed the GT3rs pumps in early alum 2.0 cases thru 964 cases, the webbs for the mains need machining and the floor of the case needs to be checked for room where the additional scavenge picks up, not a big deal with the proper equip.
Mike Bruns JBRacing.com
bavaria911 02-05-2006 11:53 PM
Thank you for the information. After consulting with our host and talking to a friend, I'll machine the case and use the GT3RS pump.
Thanks to all,
Bavaria911
Henry Schmidt 02-09-2006 05:42 AM
The machine work to install the GT3 pump in an early engine is fairly simple. It can be done at home with a die grinder or Dremel tool.
Call and I'll tell you what you need to do.
(760) 728-3062
Cheers
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
