-   -   backfiring during deceleration (http://forums.pelicanparts.com/911-engine-rebuilding-forum/265372-backfiring-during-deceleration.html)
mikey911 02-08-2006 11:12 AM
I just put 83 motor back in car after repairing broken head studs and went for test drive. During downshifting or rapid decline in RPM's engine rapidly backfires. This does not occur during acceleration only during downshifting and not at idle.
Any suggestions or ideas would be appreciated.
Mike
1974 911S
jluetjen 02-08-2006 12:28 PM
Lean mixture? Air leaks in the intake?
ONQRACIng 02-08-2006 12:53 PM
Timing? Vac leak, mixture.
mikey911 02-08-2006 12:56 PM
mixture check
On the CIS systems how do you check the mixture or change the mixture.
ONQRACIng 02-08-2006 12:59 PM
CIS needs a few special tools, Wayne has 'em.
tom1394racing 02-08-2006 07:16 PM
My experience is that this condition is caused by a leak in the exhaust (hole in muffler or leak in the heat exchange to muffler connections). Lifting off the throttle rapidly causes a rich mixture leading to unburnt fuel in the exhaust stream that gets ignited when exposed to outside air at the exhaust system leak.
Check you muffler connections for carbon trails.
afterburn 549 02-09-2006 10:03 PM
more then likely lean mixture...not necessarily a bad thing on deceleration......just too lean to fire in the c chamber....backing off is an other way to put it
