zenith carb rebuild.
i took apart my carb and found that it only had two emulsion tubes in it, then i took apart the other and found that it had all three. i would assume that the first carb should also have three, is this correct? also does anyone have any info for adjusting the floats on the zenith carbs, i searched the board but didnt have much luck.
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 02-08-2006, 11:32 AM
rw7810's Avatar
Yup, should have 3 tubes. floats are adjusted using the float level tool and shims under the check valve located in the top.
Bob Williams
70' 911T
Old 02-08-2006, 11:53 AM
