T CIS Heads with EFI?
Is it acceptable to modify the injector bung in my heads (2.4 CIS)to receive pulse injectors or should I just have the bungs plugged/welded?
-Jeremy |
The heads get too hot to allow for proper injector function.
Weld/plug the hole and install the injectors away from the heat preferably in something that is insulated from the heat. Cheers |
Thanks Henry! If I'm staying around the same displacement (looking at your upsize P/C) are the stock valve sizes ok or should I go bigger/smaller? Aside from normal r+r stuff is there anything else to do to these heads to prep for EFI?
-Jeremy |
| All times are GMT -8. The time now is 02:19 PM. |
