12mm spark plug thread pitch?
I plan to machine my heads for twin plug ignition and I need to order the tap. I don't have a one on hand, but I plan to go with a 12mm plug. Anyone know what the thread pitch is for 12mm plugs?
Thanks,
Bob
Old 02-13-2006, 08:00 PM
abit off center
cgarr's Avatar
It the same as the 14mm 1.25 do some test taping with it and check your plug in some alum, new taps are to sharp I found out.. you may want to take the real sharp edges off a new tap so your plug is not loose..
______________________
Craig
G2Performance
Old 02-14-2006, 05:43 AM
