-   -   Check this please (http://forums.pelicanparts.com/911-engine-rebuilding-forum/265599-check-please.html)
strep 02-09-2006 03:55 PM
Check this please
I pulled the fuel injection. This is what I found. Why is there oil in this area. This is the number 6 plug I believe. It has always been fouled. I pulled the motor cause it has over time started smoking. This is the only cylinder like this.http://forums.pelicanparts.com/uploa...1139529230.jpg http://forums.pelicanparts.com/uploa...1139529295.jpg
1972_911T 02-09-2006 04:00 PM
Most probably/definatly worn valve stem seals and worn valve guides, this is a common fault of the 3.2's I have just finnished rebulding mine after such issues, think its time for a top end job!
strep 02-09-2006 04:11 PM
Can I just fix this one. All the rest are dry. The motor runs strong. It has 80,000 on it.
1972_911T 02-09-2006 04:32 PM
You can do but the rest are sure to follow so if you wanna drop your engine again in a few 1000 miles for the sake of a few $10 valve guides and stem seals and a bit of machine shop work then yes just repairing that one may solve your problems for the time being. Do a search there are many threads on the topic of worn 3.2 valve guides.
steve
strep 02-09-2006 05:28 PM
Looks like I am going in. Thanks I do not think anyone has heard the last of me ;-)
cgarr 02-09-2006 05:46 PM
Well, as long as your in there!!
1972_911T 02-09-2006 06:48 PM
agh those little words, my top end refresh just ended with crank, bearings, rod bearings, piston rings, head job, arp rod bolts, oh yes and about 3 x as much as I intended to spend. http://www.pelicanparts.com/support/smileys/ear.gif
