-   -   More HP out of a 2.7 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/266145-more-hp-out-2-7-a.html)
Facey 02-17-2006 07:53 AM
HEY DD74
THIS is my first post on pelican, however i'm a long time flat-6 membet, and a huge porsche guy..
anyways i have a very modified 2.7L, it's been storked and bored to 3.1L (3065cc), is running a custom CIS setup, has been blueprinted and balanced, heads were ported and stamp polished, JE forged pistons, some fancy connecting rods, custom grind crank with a extend lift S cam, SSI headers and a flowmater 60 series exhuast (very very loud)..
this engine is a monster, it rips apart axles shafts, requires ultra high torque starters (SKY high compression ratio), and guzzles gas... its not 300hp....but its getting damn close
and this thing doesn;t leek oil....though it does have less than 6000km's on it, and it taken care of like no other... and was a expenive build up to begin with
Porschephd 02-17-2006 07:59 AM
Porsches leaking oil should not be the norm!! I hate leaking motors.
dd74 02-17-2006 10:13 AM
Originally posted by Facey
HEY DD74
I'm not familar with stroking 2.7 blocks out to 3.1. I thought 2.9 was the most you could get out of a 2.7.
Also, I have a friend who had a 2.9, and at one time when he went for a DE, they wouldn't allow his car on the track as they thought the 2.9 was a liability for destroying itself.
As it is, this friend did track the 2.9, which made close to 300 hp, but the reliability factor was suspect; supposedly the engine became very hot only after a very few laps.
I can't speak to a 3.1, except that there exists a 3.0 motor that Porsche at one point in a manufacturing run, stroke out to 3.1. But 3.1 stroked from a 2.7? Wow! :eek:
strosekmega 02-17-2006 10:19 AM
Yeah man thats sick! Post some pics, would be cool to see!
dd74 02-17-2006 10:21 AM
I don't "hate" leaking motors, but I don't particularly enjoy them, either. I look at it as "character." :D
With that said, I'm fairly confident that with a twenty to thirty year old motor, particularly one that's not rebuilt, oil leaks are going to happen.
I've never seen them to be a big deal.
Facey 02-17-2006 12:20 PM
i believe the 3.1L (barely, almost half way between 3L-3.1L)
is obatined by boring to 2.9 or 2.8, and than stroking the rest...which is alos why the compression ratio is so high.
cheers
oh...i think i made a "new member post" which has links to my carodamin site, which has lots of pictures and the full sotry of my car...i'll check.. if not i'll make it asap
dd74 02-17-2006 12:44 PM
Sounds good. I'd be interested to see this.
