oil pressure relief springs
I just noticed tonight that my 78SC has equal spring size for both of the oil pressure releif pistons. It also has no sleeve/guide on the one from the bottom of the case. I thought that the cases after 77 had the oil pressure modification and used the different springs as shown in Waynes book.
Should I just replace them with same springs?
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 02-16-2006, 06:54 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Re: oil pressure relief springs
Another motor originally built on a Friday afternoon during Oktoberfest! When I tore down my 3.2L motor, I discovered that I was missing the guide for the long spring that mounts vertically in the case. Apparently this is not exactly groundbreaking or cause for alarm as quite a few engines seem to have been missing the guide.
Your 3.0L SC is the same as a 3.2L Carrera & 3.3L 930. The pressure relief pistons used for the horizontal and vertical assemblies are the same pieces, but you should have a shorter spring for the horizontal assembly.
I would replace with what it is supposed to have, as they are dirt cheap. Part numbers are as follows to make it easier:
911 107 512 00 Relief Piston(s)
901 107 531 00 Spring (short)
930 107 531 01 Spring (long)
930 107 533 00 Guide
Good luck!
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 02-16-2006, 09:46 PM
Thanks Ralph, BIG help having all the part numbers!
Will call Pelican today.
Richard Lane
1978 911SC
Old 02-17-2006, 05:40 AM
Mine was missing the guide and equal springs too. Just replace witht he proper equipment.
-Brian
Old 02-17-2006, 07:02 AM
