-   -   Choosing Headers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/266948-choosing-headers.html)
Facey 02-17-2006 09:15 AM
Choosing Headers
Hey guys
I own/drive/build a 1975 911s, which is pretty modified, and some what gruppeB,
the engine is a bored/stroked 2.7 ~3L, and is somewhere north of 260hp (but still under 300). its a fire breather and is tons of fun. however i do find that the power comes on very high, and that the throttle response is lacking.... both fixable at the expenise of top end ...but i decided to do something else
i baught a 3.6L twin plugged beast.... it was a 2001 Jerry woods crate engine. the prvious owner wanted mroe than what came outta the crate (which was a 3L case pushed out to 3.6L, twin plug heads, EVO 2 s cam, with twin plug heads, custom crank, and JE forged pistons (9.98:1). I am not aware of it fuel delievery system.
however as it goes into my car, it has 46mm webber's, with extended veloicty stacks, 6 coil crank fire/triiger igntion, more arrgressive cams, 104mmMAHLE pistons, re-angled oversized valves, ported heads, smooth polished, and pretty much every other goodie u can think of.... excpet headers.... which is has none.
i have been thinking about the B&B system, however i have no experience with them, and was just wondering what u guys would recommend?
i believe i want a very free flowing tuned exhuast system, featuring twin tips, AND the heater boxes....
so whatta think?http://forums.pelicanparts.com/uploa...1140196514.jpg [img]
Steve@Rennsport 02-17-2006 09:55 AM
I'd use the GHL ones,.........:)
Facey 02-17-2006 01:38 PM
got a link?
or phone number?
i'd just like to talk with them a price it out....as i know B&B is expensive....but power and noise is my goal.....(in that order)...and than looks...and then cost....lol...within reason..
Dadofour 02-17-2006 07:07 PM
ghl
Pelican GHL Headers
Try our host
JohnJL 02-17-2006 10:12 PM
Hi Dad...you do have expensive tastes! Linky no worky tho...I think it is this one...http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_exhprf_pg12.htm#item
I recently received my Bursch headers from our host but haven't had a chance to run them yet. The welding was not, shall we say, "artful." The black paint coating is cheap too...I'd rather they come bare steel so I could easily ceramic coat them. I'll have to have them blasted first.
I'd get in touch with Jerry, he should be able to recommend the right headers. Of course, Steve@Rennsport is also a Jedi...
JohnJL 02-17-2006 10:17 PM
You're also going to need to upgrade your brakes with that transplant!
Dadofour 02-18-2006 05:58 AM
Hey John. I am interested in why you went Bursch (other than price).
I am shopping headers and exhaust as well, and am trying to find headers that have some proven benefit in performance.
What are you putting on the end of it?
Porschephd 02-18-2006 01:10 PM
B&B has a better collector design and has proven on our dyno time and time again to create more power than the others out there. I would also do either the B&B muffler or use the Fabspeed muffler. You will need to do some fabbing to make this work on the older body but it is not a big deal.
I have no issues with the B&B muffler and in fact run one on my wife’s 3.6 in her 76S Targa. I also run the fabspeed on other conversions we have done and was very pleased with the results as well.
JohnJL 02-18-2006 01:20 PM
Hi Than,
I am just experimenting. There's an active aftermarket here, so if I don't want them/not happy with them someone will want them. Not much need for heat here!
There is some guy here who just spend $5000 on his exhaust system (mandrel-bent stainless steel 'bundle of snakes'). I'm just kind of keeping quiet until we're both out on the track...
I'll be gutting a stock muffler and welding up a 2-in2-out setup. That is pretty common on the tracks here...and just below the track db thresholds.
Carrera3.5L 02-18-2006 01:49 PM
George Narbel from European Racing Headers in Henderson, NV has been making these mild steel headers in various diameters for years. Can be used with a street muffler by adding his adaptor pipes. They also have been "dyno proven" over the years.
They come with a high-heat paint, but for the best long-term performance it may be wise to ceramic coat inside & out.
http://forums.pelicanparts.com/uploa...1140299116.jpg
http://forums.pelicanparts.com/uploa...1140299166.jpg
Cost of the headers with the adaptor pipes is about $600 retail, far cheaper than the all stainless units out there. If you live in an environment where the higher grade material would be beneficial, stainless is probably a better option but for those of us who don't need or want to pay for the higher grade material these work just fine.;)
Ralph
JohnJL 02-18-2006 04:04 PM
Ralph, I just see black boxes, no images...
Carrera3.5L 02-18-2006 05:04 PM
Yeah, I do too...:(
Have no idea what happened...
Let's try again?:)
http://forums.pelicanparts.com/uploa...1140310976.jpg
http://forums.pelicanparts.com/uploa...1140311022.jpg
If these don't work than I give up.;)
Ralph
Carrera3.5L 02-18-2006 05:13 PM
Oh well, I can't get it to work.
Anyway, I just read the original post and he wants heater boxes, which take's George's headers out of the equation anyway.
http://forums.pelicanparts.com/uploa...1140311565.jpg
Looks like the 3rd times the charm. My computer ineptness is pathetic.:(
Ralph
Steve@Rennsport 02-18-2006 09:09 PM
Early B&B headers made FAR more power than the ones they make now so we use either GHL header/heat exchangers or George's headers that we modify for different displacement engines.
Porschephd 02-19-2006 06:44 AM
Georges headers are excellent and hard to beat for the price. He makes good stuff. Just no heat unfortunately.
I am not sure the last time you had a set of B&Bs on the dyno but I have within the last 6 months seen different on my dyno
Steve@Rennsport 02-19-2006 04:36 PM
Steve:
We've tested 15-16 sets of B&B headers over the past 10 years on our engine dyno and all of the early, first-gen B&B's did a LOT better than anything they've made in the past 4 years. :)
I suppose its all relative.
Dadofour 02-19-2006 04:45 PM
George's Headers
Steve,
What types of modifications do you do to George's Headers? I am considering a set combined with the M&K Stingers.
Porschephd 02-19-2006 05:08 PM
Steve,
I agree in the past there were issues, however in the last year or so things have changed. You may want to revisit that. As I mentioned I did some test on both the NA and turbo cars to find some stayed the same and some had done better than they did in the past. I am trying to get our money’s worth out of this thing(very expensive dyno).
It is all relative as you mention. Something tell mention to Jeff to give another shot.
Steve@Rennsport 02-19-2006 06:20 PM
Steve:
We recently (within 3 weeks) did a 3.6 RS spec motor and compared a new set of B&B's, an old set of B&B's, and a pair of George's headers. The old set gave the best results, followed by George's, and then the new B&B's. Pretty current stuff,....:)
Than:
We change primary lengths based on displacement and camshaft selection.
MBEngineering 02-21-2006 12:05 PM
HI try www.btbexhausts.co.uk thay will make what you require for the engine, thay fitted a set of manifolds to a engine i helped build for the east african rally (3.0l) the car came 2nd with good power throughout the rally.
regards mike
Larry Herman 02-21-2006 05:42 PM
I ran George's headers on my old 3.2 Carrera. I had them Jet Hot coated with the flat black high temp stuff, and they stayed perfect for 6 years till I sold the car.
