-   -   Multiple cylinder base gaskets ??? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267174-multiple-cylinder-base-gaskets.html)
hobieboy 02-18-2006 04:54 PM
Here's the background - I'm not sure how thick I need for the base gaskets as I'm using a different set of cylinders that happened to have been shaved.
If I ended up needing say .75mm, would it be ok to use a .5mm + a .25mm or should I go out of the way (e.g. not getting it from our host) to find a .75mm (or worst yet 1mm) gasket?
thanks...
Jeff Alton 02-18-2006 05:26 PM
You can stack, I have stacked two a couple of times with no leaks at all. I think Henry has them in the different thicknesses though.
Cheers
hobieboy 02-20-2006 06:59 AM
Thanks for the confirmation Jeff - that's what I thought as well.
Now, I need to pre-assemble & measure the clearance. Once the gaskets are squished once, are they re-usable? My thinking is: if I start with, say, 2 .25mm ones, and end up needing 3. Can the 2 be re-used?
thanks.
adomakin 02-23-2006 12:21 PM
ive stacked mine. i think the general consensus is that its ok if you dont go mad
ChrisBennet 02-23-2006 03:23 PM
Competition Engineering also sells thicker base gaskets.
-Chris
stevepaa 02-23-2006 03:52 PM
I would just go with the correct height single gasket after you figure out what that height should be.
good luck
You might also check with Jerry Woods. They made a single for each side for me.
hobieboy 02-23-2006 04:07 PM
Thanks for the input guys...
I'm doing some pre-calculation prior to assembly, so hopefully the clearance will be ok that I don't have to dismantle the p&c.
I have also been told from a few experience builders that stacking 2 is ok, so will probably leave it at that if I only need 2. But will likely get a thicker 1 if I end up needing 3.
jgparker 02-24-2006 04:30 PM
I asked a similar question a while ago and got some good info in response. Here is the thread:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/124956-cylinder-base-shim-how-thick-too-thick.html?highlight=base
Good luck,
JP
