-   -   Are these cylinders junk? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267218-these-cylinders-junk.html)
andrew15 02-18-2006 10:24 PM
I have 3x 95mm nikasil cylinders that I believe are junk. They all have a 'chunk' out of the lower edge from some debris in the engine - ie a broken piston from another cylinder :(
Anyway - these are junk right? I just want to make sure before they make a loud noise in the garbage bin.
Regards,
Andrew M
http://forums.pelicanparts.com/uploa...1140329903.jpg
http://forums.pelicanparts.com/uploa...1140330219.jpg
tab tanner 02-19-2006 05:26 AM
If you grind that area smooth I think you can still use them. The rings never get thet close to the chipped area so you should be OK. Please don't flame me for this GUYS
dyerkes 02-19-2006 05:52 AM
cylinder?
The damage shown on the bottom side of your cylinder is not an issue. The rings come down only as far as the where that dark ring starts.
1986 911 Turbo
ChrisBennet 02-19-2006 08:29 AM
I might add that you'll want to check to make sure they weren't banged out of round when they got wacked.
-Chris
id911T 02-19-2006 12:05 PM
If they're still round, I'd just clean up the nick and put them back into service.
Mike Juzenas 02-19-2006 04:51 PM
Why don't you take them down to Ollies and get them moon cut? Apparently you have to watch on Nikasil because it can start to chip off (or so I am told). If the moons will not be where the chips are I am sure that they can take a bit off the bottom anyways to get rid of the rough edge.
Cheers,
Mike
Porschephd 02-19-2006 05:26 PM
They should be fine but have them checked. It is not uncommon to relief cut the bottom for better windage. What caused the nick?
