-   -   JE's for a 2.2T (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267280-jes-2-2t.html)
id911T 02-19-2006 11:40 AM
JE's for a 2.2T
My pistons and cylinders are both close to their maximum repective wear specs so I was thinking about boring my cylinders to 85mm and getting a set of pistons to match. I'm a machinist and boring the cylinders shouldn't pose any problems, but I need a ballpark on how much the pistons (like JEs) are going to cost from someone who has done something similar. If the pistons are going to set me back 1200$, I might as well wait and see if I can find a factory set of p/cs.
thanks
andrew15 02-20-2006 04:37 PM
Check with Henry at Supertec or they guys at EBS Racing - New JE's should be around $900-1000.
Regards,
Andrew M
