-   -   Header Coatings What? Who? How much? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/267503-header-coatings-what-who-how-much.html)
eddie914 02-20-2006 02:59 PM
The 3.2 for the 914 is nearing completion!
I hate to put the rusty Bursch headers on the shiny new(er) engine.
What are the options for coatings? Pros? Cons? Who in the Seattle area? How much?
Is high heat paint a waste of time?
Eddie
jpahemi 02-20-2006 03:06 PM
Yes High Heat Paint is a waste of time; with the heat cycles the paint won't hold up very long.
j.p.
914/6 02-20-2006 04:16 PM
Performance Coatings in Auburn
id911T 02-23-2006 06:37 PM
Eddie,
Use VHT Flameproof coating. It comes in a rattle can like spraypaint. It requires pretty detailed surface prep (details on website), and after it's applied it needs to be oven cured if the part won't see enough heat to cure it in situ. This stuff is so tough one of the recommended uses is preventing chrome headers from bluing by spraying it INSIDE the pipes as a thermal barrier.
diabolos88 03-05-2006 02:13 AM
I'vce always used JETHOT coating on my other cars headers. It lowers under hood temps significantly too. not cheap!
dean 03-05-2006 05:24 AM
I think that is a rumor started by JetHot. I'd like to see some independant data on the temp lowering.
Dean
shbop 03-05-2006 08:14 AM
If you can't oven-cure the spray-paint, it's not worth doing. It will only look good for a very short time. Ceramic coating would be your best option if it's available in your area.
tom1394racing 03-05-2006 12:17 PM
Here's another current thread on the same subject.
http://forums.pelicanparts.com/showthread.php?threadid=265280s
id911T 03-05-2006 04:11 PM
shbop is right about the oven curing with VHT. If the prep and curing cannot be performed properly, it's best to chose another option. Most v8 shorty headers will cure in place if they are driven hard before being exposed to rain and the like, but I don't know about 911 headers. I'd oven bake the VHT to be sure. It holds up well it you do it right.
fastfredracing 03-09-2006 04:42 AM
Jet hot is very nice, we have used it for years on other hotrods, (before I became a cerified porsche junky). It will keep its original apearance for a long time, we had used a set of headers on a snow plow truck for a customer,a and two seasons later, we could not believe how well the stuff was holding up.
