 Vibration Damper and L/W Flywheel (993) We are having an interesting discussion with a customer and I need a little input. His 993RS is fitted with the non-damper l/w single crank pulley. Before he took delivery the engine was rebuild by Porsche and a l/w flywheel setup (non DMF) was fitted. The question now is - should one fit a vibration damper pulley on the front of the crank to compensate for the new l/w flywheel setup? We have several 964/993 engines running the Clubsport type l/w flywheel, and sofar have had no problems. Would there be a difference btw a road and a pure track setup? i.e. use vibration dampers only for a road engine? Regards Tom |
 Tom,  Check the post "New problem with 3.6 case" on this page. Lots of great info. |
 A case of premature posting... Just read that thread and you're right - good info. Tom |
 The dual mass flywheel was intended to address transmission gear rattling issues(as was the original rubber center clutch) Quote:
 993 Cup cars did use the harmonic balancer but I believe that was because of production line expediancy related to the early date of their manufacture |
| All times are GMT -8. The time now is 04:35 PM. |
