-   -   case assembly (http://forums.pelicanparts.com/911-engine-rebuilding-forum/268607-case-assembly.html)
bbaer6676 02-26-2006 02:41 PM
case assembly
Getting ready to put the case halves back together, have two questions. i know the through bolts are torqued at 25lbs, is that the same for all the locking nuts on the top and bottom of the case? also i can seem to find any loctite 574 at my local shops, is there any other sealant that you have found to work good? thanks in advance.
brian
Jeff Alton 02-26-2006 04:03 PM
Do a search on case sealing, many very good recent threads. I am using threebond 1104 which a number of people are using with success. I comes highly recommended. You can get it at most M/C shops.
Cheers
