JoeMag's Avatar
Sealing up leaky 930 trans inspection/fork holder cover
My trans insp cover is leaking a little. Probably very simple fix. I was thinking of just NOT using that very thin paper gasket and using a layer of threebond 1104 as sealant.
Sound like good solution? Other suggestions?
Old 03-02-2006, 06:58 AM
Forced Induction Junkie
WERK I's Avatar
JoeMag,
If there is a leak, there is something else going on. This area should be dry inside unless the rear main seal or the transmission input shaft seal are leaking. Any oil that gets on the clutch plate or flywheel spells doom for the clutch surfaces.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-02-2006, 10:41 AM
resident samsquamch
sand_man's Avatar
Post a picture...
-jeff
Old 03-02-2006, 10:51 AM
JoeMag's Avatar
sorry, not that fork. Ref pic below. ...the inspection cover that is on the bottom of the trans housing that covers the two gear stacks.
Old 03-02-2006, 12:20 PM
WERK I's Avatar
Oh, T-H-A-T cover!
I would use the paper gasket with Curil T on both sides.
Dave
Old 03-02-2006, 03:54 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Clean both gasket surfaces CAREFULLY with a razor blade and wipe it down with brake cleaner. Make sure to keep the blade perpendicular (90 degrees) to the surface and "scrape". Do not knick or cut the surface in the process. You need to get rid of every little bit of residue from the old seal. Then use the paper gasket with a thin coat of Curil-T on both sides. It will be bone-dry
'74 Targa 3.6 (not stock ) - '01 C4 (almost stock) - '00 ML430 (stock)
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2 - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-02-2006, 11:03 PM
JoeMag's Avatar
Great. ...curil-T it is then!
Old 03-03-2006, 10:13 AM
