clutch issues 915
Hi,
I've just recently replaced different parts in my clutch assembly and now everything works fine. The only problem is that the meeting point is very low. The screw was already adjusted so that there is 1mm clearance. What can i do? If the screw is touching the fork, does that mean the clutch will not be fully engaged? Thanks for your help. Adam |
Adam:
You may need to adjust the overall length of the cable; that 1mm at the clutch arm is correct and sets the freeplay. |
the clutch pedal itself cable wise has very little freeplay... the clutch shaft will rotate maybe 1 degree before the clutch cable is taut.
| All times are GMT -8. The time now is 09:01 AM. |
