935 3.2 - Carrera 3.2 barrels
Can anyone tell me if the 935 3.2 cylinders compare well/at all with the Carrera 3.2 cylinders. Would the 3.2 Carrera cylinders give better service than the std turbo cylinder in a modified 930 turbo motor?
Thanks |
MBruns for President
Probably the 965 cylinders would be the best choice. They are fully finned...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
HI the 935/3.2 cylinders are 95 mm bore and thicker than the 3.3 turbo at 97 mm, i ran 935 pots/pistons on a hill climb car, thay will take more boost than the std' 3.3 pot's, the 935 and the 3.2 cylinders are both fully finned, PM me for speck' of the engine if you are intrested.
regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
935 cyls.
Be sure to check the length of those 935/962 cyls most were 89.3mm hgt. vs. 85.3mm of the std 3.0/3.2 911,s
Mike Bruns JBRacing.com |
Thanks for the replys guys. Is the 89.3 dim for the 4 valve motors?
Regards Graham |
cyl hgt
No, on the 935 and early air cooled 962 the cyls were longer because of the machine work on the case in the area of the cyl base they machined that area flat for more area on the base of the cyl and use "O" rings to seal the spigot on the cyl down in the case like the 3.8 RSR, and then they used a much larger base shim to set the deck hgt. Have you ever noticed the 930 base shims get mashed out from under the cyls. and cause a big oil leak? its from detonation, the narrow copper shims cant stand that so the race engines used a steel shim and it goes over the cyl studs and has much more area. so thats the reason for the longer studs/cyls.
Mike Bruns |
