LinkBack | Thread Tools | Rate Thread |
Pitting on cam's
SWB |
NM read waynes book... off they go to camgrinder
SWB |
i think you'll find that they are probably ok to use, there are other threads around that talk about this with similar pitting where others have ok'd them for re use.....
Andy 1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going ![]() |
John (camgrinder) will probably comment but it seems this is a common issue on SC's. Mine had pitting, exactly like yours and I just got the cams back from John. He seemed to indicate most of them did habve issues...this car only had 75K, great service records...almost certainly not dirty oil.
Richard Lane 1978 911SC 1973 "Clean" RS clone |
i know if it was worn down you would be abe to feel a ridge where it rocker doesn't ride.. but no ridge...
thanks for the advice!
SWB |
If you measure the lobe at the base circle, you will most likely find some lobe taper. Meaning the lobe is bigger in diameter closer to the bearing journal. This concentrates the pressure on a smaller area leading to this type of failure. Not a big deal to regrind. And yes I have seen a lot of these. Almost all were the 9301051477R cores.
I wouldnt recommend it, but if anyone does try to reuse a cam like that be sure to keep the rocker arms on the same lobes.
John Dougherty Dougherty Racing Cams |
Thread Tools | |
Rate This Thread | |
