-   -   993 RSR cam timing? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/270224-993-rsr-cam-timing.html)
Cookie Porsche 03-07-2006 06:02 AM
993 RSR cam timing?
Were do you set the cam timing?
I have had three ideas - from 4.1 - 6.5mm
993RSR cam (factory) #993.xxx.xxx.90
We have pocketed the 102mm Mahle pistons so clearance shouldn't be an issue.
Race engine - max rpm +/- 7000rpm.
Regards
Tom
Steve@Rennsport 03-07-2006 08:59 AM
Tom:
Right out of the Factory 3.8 RSR manuals: 4.6mm @0.10 valve clearance
