Oil Leak ? ?
Hey guys,
Just wondering if this oil leak is comming from the rocker arm shaft? You can see that one section of the top intake rocker arm is black with leaked oil. Or is this a bigger problem? Is there any way to insert the rsr gaskets without taking the engine down to a lower level?
Old 03-07-2006, 11:07 AM
mbr mbr is offline
Banned
Yo for a post here and you will get a faster response! www.globalmotorsonline.com
Old 03-09-2006, 12:21 PM
Sorry I am not sure if I was clear enough the first time. I added arrows to what I am concerned about. The RED arrow is pointing towards the area with excessive oil deposits, the GREEN arrow is pointing towards the next cylinder which does not have the oil leak problem.
Old 03-09-2006, 12:33 PM
MBruns for President
JeremyD's Avatar
Take your crap someone else dickweed
Old 03-09-2006, 01:21 PM
JeremyD's Avatar
Hard to tell - but a rocker shaft seal could be your issue. how many miles? And yes, you can install RSR seals with the motor in - but it's 10 times easier if you drop the engine.
Old 03-09-2006, 01:24 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I think in that area it could be a leaking rocker shaft or a leak between the cam tower and that head, unless i'm missing something.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 03-09-2006, 01:26 PM
Thanks guys I appreciate it. I have the engine out of the car already, it has 76,000 miles. I just didn't want to tear the chain housings off, then the cam housings, and all that jazz if I didn't have too. I could try tightening the cam tower bolts down a bit. If I remember correctly there is no gasket between the heads and the cam towers, so is there any way I could fix that if it is the problem. I imagine fixing that issue would essentially be a top end rebuild.
Would you think that a cam tower to head leak is a critical thing to fix immediately or something that should be watched and fixed sometime down the road when more critical issues are at hand?
Thanks a lot for your input it is very much appreciated.
Old 03-09-2006, 01:52 PM
JeremyD's Avatar
Check the torque on the headstuds - always - and yes, the better fix is the top end - otherwise you clean it up - and look for where it's leaking....
Old 03-09-2006, 02:00 PM
I would install the RSR things and redo the seal b/t the camtower and the heads.
Old 03-12-2006, 10:12 AM
adomakin's Avatar
like Jeremy says...
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 03-13-2006, 11:14 PM
