shbop's Avatar
Advise neede
Just tearing down my 66' 2.0. After removing the rockers and cam on the right side, I found this: The rocker looks ok, but this is my first re-build on a 911, and I would sure appreciate any advise. Thank you in advance! Aloha, Jon
Jon
Old 03-10-2006, 01:34 PM
resident samsquamch
sand_man's Avatar
Clogged cam spray bars? Why the rebuild? Just routine or did something break?
-jeff
Old 03-10-2006, 01:37 PM
shbop's Avatar
spray bars seemed ok. I found broken rings on #4 & #5. I guess that solves the smoke problem, although I haven't yet taken the heads apart, so I'm not sure about the guides.
Jon
Old 03-10-2006, 05:51 PM
Jeff Alton's Avatar
Hard to tell just what it looks like from your pic, but some pitting on SC cams if not unheard of. I would send them to camgrinder and have him give you your options on them.
Cheers
jeff@turn3autosport.com
997 S 4.0, Boxster 2.7, Boxster S race car, 958 Cayenne TT, VW GTI 2.1 TSI, Mini Cooper S JCW, Cannondale Supersix EVO SRAM RED E-tap, Cannondale Slice SRAM RED E-tap
Old 03-10-2006, 05:59 PM
resident samsquamch
sand_man's Avatar
When you say: "seemed ok", did you actually remove the plugs in the cam housings and clean the spray bars? What's the history on the engine? How many miles? Was the oil changed at regular intervals?
-jeff
Old 03-10-2006, 06:12 PM
resident samsquamch
sand_man's Avatar
Cheers
Is that an SC cam? I thought this was for the '66.
-jeff
Old 03-10-2006, 06:14 PM
camgrinder's Avatar
Thats unusual for a 66 camshaft. But easily repaired.
John Dougherty
Dougherty Racing Cams
Old 03-10-2006, 08:40 PM
shbop's Avatar
John, Thanks for the reply. How do I contact you for repair?
Unfortunately, I don't have any history on the motor. I have not pullled the plugs on the spray bars. When I shot air and carb cleaner through them, they seemed ok.
Jon
Old 03-11-2006, 05:32 AM
