-   -   Dial indicator (http://forums.pelicanparts.com/911-engine-rebuilding-forum/271090-dial-indicator.html)
don hopkins 03-12-2006 10:21 AM
Dial indicator
Where's the best place to buy a 1-10mm dial indicator since Pelican doesn't have them?
ChrisBennet 03-12-2006 10:30 AM
MSC, McMasterCarr and Enco all sell them online if that helps.
-Chris
MBEngineering 03-12-2006 12:21 PM
HI try www.kcir.co.uk he has all sizes new and re'con/re'cal i have had indicators from him, he is good and has all the ajustment tools to repair any DTI/micrometers. good price to.
regards mike
don hopkins 03-12-2006 02:23 PM
How do I know which ones will fit the z-block holder?
Motorhead-45 03-12-2006 03:33 PM
Another option although I'm sure it's of lesser quality than some of the other suggested vendors....displays in metric and SAE and often on sale. I bought mine for $14.99 3 weeks ago.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93295
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=5646
sand_man 03-13-2006 03:46 AM
I know, I know...CHEAP TOOLS...YOU GET WHAT YOU PAY FOR...YADA YADA!!! But here's another vote for Harbor Freight. I bought the digital one and the old skool analog/dial one. I think they're good enough for what I need!
MBEngineering 03-13-2006 06:33 AM
HI you will req' a dti with a 8mm shaft (to fit the porsche Z holder) and a extension of app'20/25mm long, depending on the range of the dti you use, i have a 20mm range dti with a 20mm extension.
regards mike
adomakin 03-13-2006 11:09 PM
I made my own extension from some thick wire-worked a treat
don hopkins 03-16-2006 06:29 PM
thanks
