shbop's Avatar
Which ones are these? Can I bore?
Attached is a photo of a piston and cylinder from my 66' 2.0 The markings at the base of the cylinder read:
80 ZD 3
Which cylinders do I have?
I noticed in Wayne's book, under machine shop stuff, an entry for boring.
Questions: (1) Can these cylinders be bored? If so by how much?
(2) The head is stuck on the number 4 cylinder. I tried tapping from the inside of the cylinder, down on the head with my plastic dead-blow, but no luck. I'm really nervous about breaking-off fins. Is there a better way to remove a stubborn head?
Thank you in advance! Aloha, Jon
Jon
Old 03-12-2006, 07:28 PM
Correct me if I'm wrong, that looks like a biral both by the coloring and the way the fins are cast. I picture from the top would help the clarify that further, as you can physically see two dissimilar materials in the face of the cylinder that seats against the heads. The bore should be 80mm, which you could take out to 81mm with some fresh JEs.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 03-13-2006, 04:58 AM
shbop's Avatar
Thank you Charles. Your description of what you couldn't see was absolutely correct.
Jon
Old 03-13-2006, 05:40 AM
MBEngineering's Avatar
HI pop it in the oven and warm it up, then try taping it off with a block of wood up the cylinder. good luck
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 03-13-2006, 06:38 AM
shbop's Avatar
Aloha MIke. Too funny. I was thinking about doing just that. In another hour my wife will be walking out the door, and my cylinder will be sliding into the oven. Thanks again!
Jon
Old 03-13-2006, 07:18 AM
MBruns for President
JeremyD's Avatar
are BBQ grill may make the wifey more happy
Old 03-13-2006, 11:08 AM
shbop's Avatar
10 minutes in the oven, and it popped right off. Thanks again!!
Jon
Old 03-13-2006, 12:04 PM
Can 80mm biral cylinders be bored to accept 84mm 2.2/2.4 pistons?
andy
Old 10-19-2008, 07:03 AM
3 restos WIP = psycho
kenikh's Avatar
andy
Sadly, no
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-19-2008, 08:01 AM
The cylinder is an 80 mm biral. These were standard for the early 2.0 motors. The 80 mm cast iron cylinders were introduced in the T motors for '68 and later.
The piston is also standard fare for the early 65-68 motors. A nice "slipper skirt" piston.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-19-2008, 05:45 PM
304065's Avatar
LOL Tom! We're lucky they didn't use three compression rings!
80s can be bored to 81.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-19-2008, 07:13 PM
What do you guys mean by slipper skirt piston? How many rings would my JE's have?
Old 10-25-2008, 11:27 AM
HI andy
if you make a jig to hold the cylinders when boring them, you should get the 84mm 2.2/2.4 pistons to fit OK, as I have a 2.0Lt running round with some JE piston at 86mm in biral cylinders on a fresh bore, now covered over 3,500 miles of spirited driving by the owner.
regards mike
Regards mike
Old 10-27-2008, 06:21 AM
