-   -   '82 930 distr install -- correct loc'n? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/271247-82-930-distr-install-correct-locn.html)
JoeMag 03-13-2006 07:07 AM
When you install the distributor with #1 at TDC should it look like A or B below? Also, I'm assuming it's with the hold down nut in the middle of the slot for timing adjustment.
http://forums.pelicanparts.com/uploa...1142262424.jpg
