12mm 12 plug plugs
Hello all.
Seeking opionions re suitable plugs please.. Kind regards David |
What is your motor specs? I take it this is for your lower set on a twin plug motor?
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yes, indeed it is.
Its a full on racer with d60 cams and 11.5 CR. Kind regards David |
Hey Man!
You will want to use NGK motorcycle plugs. I can't remember the number off the top of my head. I get back to ya tomorrow on it.
Thanks! Don Ramsay E Mail: aircooledclassicsporsche@gmail.com The father of 964 Backdating! www.aircooledclassics.co www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/ |
Plug number
Your looking for NGK dcpr6e which are 12 mm plugs.
tadd
1967 912 with centerlocks… 10 years and still in pieces! |
That is very helpful, tadd.
many thanks. I assume I can try a few plugs round this heat setting provided they have similar dimensions? Any other favourites please? Kind regards david |
Tadd hit it right on the head. That's what we have been using too.
