-   -   Intake bolt patterns? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/273235-intake-bolt-patterns.html)
DUK 03-23-2006 06:03 PM
I'm thinking of converting a 3.2l intake manifold to fit my 2.7l. I was wondering if the intake bolt apttern is the same. What I was thinking of doing was some phenolic spacer/adapters, if the bolt spacing is the same. Would this work or not??? Thanx, Duke
Porschekid962 03-23-2006 06:09 PM
AFAIK the intake manifold bolt patterns did not change until the 3.6 litre motors came out which had 3 studs instead of 2. If you do it dont forget to port match it!
jpnovak 03-24-2006 07:26 AM
It does work. It is a bolt on. Yes you must port your heads to match the intake. Don't forget you will have to have a custom chip or aftermarket ECU to get the EFI to work properly with your 2.7
DUK 03-24-2006 01:47 PM
Thanx guys, I'm thinking of doing the megasquirt conversion for my cis. And using the 3.2 manifold, any opinions?
briankeithsmith 03-24-2006 02:07 PM
Way to go Duke! Put that intake on there and let's EFI that thing!
DUK 03-24-2006 02:31 PM
My thoughts exactly. BTW cool videos and great job on your racing, sorry we haven't gotten together. My wife is having some more problems and I've been taking care of her. Call me sometime and we'll get together.
