magic930's Avatar
Piston to cylinder clearance
When making the measurement is it:
BORE - PISTON / 2 = Clearance
or
BORE-PISTON = Clearance
In other words is the clearance measurement both sides of the piston or one side?
Old 01-30-2004, 09:41 PM
PJMARKOW's Avatar
The clearance would be the (bore - piston size) / 2, ie cylinder bore to piston (all round).
PaulM
1977 930
1993 Nissan GT-IR
2000 Subaru WRX
Old 01-31-2004, 02:45 PM
CBRacerX's Avatar
I don't think this is correct, is it? I thought the clearance was the total clearance for the piston on one side with the other at zero clearance, not the "all round" clearance.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 03-29-2006, 07:39 PM
Jeff Alton's Avatar
Chris has it right, from what I understand. I posed this question not all that long ago on the board as well. It is cyliner bore - (minus) piston OD.
Cheers
www.turn3autosport.com
Old 03-29-2006, 10:17 PM
magic930's Avatar
The right answer 2 years later ... I ended up getting new P&C's anyway.
Old 03-30-2006, 07:50 AM
CBRacerX's Avatar
Procedure to measure cylinders can be found here: Another 3.6->3.8 Rebuild Thread...
Chris
Old 03-30-2006, 10:58 AM
Jeff Alton's Avatar
ooops, I never even looked at the dates!!
Cheers
Old 03-30-2006, 11:38 AM
CBRacerX's Avatar
I just wanted someone searching (like _I_ was) to find the right answer.
Chris
Old 03-30-2006, 11:48 AM
