case assembling and nuts....
Hello
shall i consider locking-nuts to apply the right torque on the case assembly ? (peripheral nuts) what is factory recomandation about this ? regards Philippe |
Good timing! I will be sealing my case in a few weeks. To add to the question above. Can nylock nuts be used on the case perimeter? Or are the factory style nuts that are deformed slightly the way to go.
I bought the hardware rebuild set from our host. Highly recommend. Mostly uses nylock for perimeter, but a few of the special deformed style lock nuts for some of the interior requiements such as oil pump and other locations.
Nylock on perimeter is fine. Most of the gasket kits don't have the aluminum crush washers anymore. They have steel washer instead. I don't like them so I use the old aluminum washers. You can also buy the aluminum crush washers (probably from Pelican). If Pelican doesn't have them I bet EBS does.
-Andy |
some additional info here:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/258518-can-i-replacing-case-parimeter-washers.html use steel not aluminum... |
| All times are GMT -8. The time now is 10:50 PM. |
