Piston to cylinder clearance
When making the measurement is it:
BORE - PISTON / 2 = Clearance or BORE-PISTON = Clearance In other words is the clearance measurement both sides of the piston or one side?
David |
The clearance would be the (bore - piston size) / 2, ie cylinder bore to piston (all round).
PaulM 1977 930 1993 Nissan GT-IR 2000 Subaru WRX |
I don't think this is correct, is it? I thought the clearance was the total clearance for the piston on one side with the other at zero clearance, not the "all round" clearance.
Chris https://dergarage.com ‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8 |
Chris has it right, from what I understand. I posed this question not all that long ago on the board as well. It is cyliner bore - (minus) piston OD.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The right answer 2 years later
... I ended up getting new P&C's anyway.
David |
Procedure to measure cylinders can be found here: Another 3.6->3.8 Rebuild Thread...
ooops, I never even looked at the dates!!
Cheers
I just wanted someone searching (like _I_ was) to find the right answer.
