Supercharging a 2.7 engine
Helo
Can anyone on this forum give me some detailed info for supercharging a 2.7 engine.
What kind of cilinders, pistons, inlet openings,cams,...turbo??,....etc.
All info is welcome
My personal e-mail adres: bart_elsen@jabil.com
Thanks in advantage
Regards
Bart
Old 04-02-2006, 06:17 AM
BReyes's Avatar
First thing, make a budget, Then plan your build, including inspection machine shop/parts pre/wip measuring.
I know there are kits you can install/update, eg http://www.goingsuperfast.com/
Know you will spend what you can buy a 930 for.
Good luck.
Bernard
Old 04-02-2006, 06:26 AM
Try not, Do or Do not
Henry Schmidt's Avatar
First piece of advise is to start with a 3.0 instead of a 2.7. It is hard enough to keep a normally aspirated 2.7 together let alone adding the increased pressures of a supercharger.
The mag case will freak out from the extra heat and cylinder pressures.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-03-2006, 09:06 AM
Hello Henry Schmidt
I sent you a Pm
woud you tell me (or anybody else) if a CIS 2.7Head would fit a stock euro carrera engine ?
best regards
Philippe
Old 04-03-2006, 09:54 AM
