-   -   935 camshaft timing needed (http://forums.pelicanparts.com/911-engine-rebuilding-forum/274753-935-camshaft-timing-needed.html)
edbaus 04-01-2006 11:55 AM
Hi,
I need to know the timing height of the 935 camshafts.
It looks like I need to crash my last plan for modified 934 camshafts for now.
Ed
Carrera3.5L 04-01-2006 12:22 PM
Ed,
Please don't take this as gospel until you receive a confirmation from someone else, but my old notes from years ago indicate 935 cams should be timed at 4.6.
My notes also indicate that 934 cams were timed at 3.65 as a reference.
Ralph
MBruns 04-03-2006 06:51 AM
935 timing
The tear down notes on the one we have in progress were at 4.6mm, it is a late 935/early aircooled 962, the casting # on the 4-5-6 side is 930 105 152 01 the other is in the housing for mock up
hope this helps
Mike Bruns JBRacing.com
Henry Schmidt 04-03-2006 08:20 AM
4.65 mm
MBEngineering 04-04-2006 01:08 PM
HI i will go along with that at 4.65 +/-0.1 for 930.105.151.01 and 930.105.152.01 cams, and 934 at 3.5-3.7 for 930.105.155.00 and 930.105.156.00 cams just for a 4th opi'
regards mike
