-   -   Supercharging a 2.7 engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/274869-supercharging-2-7-engine.html)
Porscheke 04-02-2006 06:17 AM
Helo
Can anyone on this forum give me some detailed info for supercharging a 2.7 engine.
What kind of cilinders, pistons, inlet openings,cams,...turbo??,....etc.
All info is welcome
My personal e-mail adres: bart_elsen@jabil.com
Thanks in advantage
Regards
Bart
BReyes 04-02-2006 06:26 AM
First thing, make a budget, Then plan your build, including inspection machine shop/parts pre/wip measuring.
I know there are kits you can install/update, eg http://www.goingsuperfast.com/
Know you will spend what you can buy a 930 for.
Good luck.
Henry Schmidt 04-03-2006 09:06 AM
First piece of advise is to start with a 3.0 instead of a 2.7. It is hard enough to keep a normally aspirated 2.7 together let alone adding the increased pressures of a supercharger.
The mag case will freak out from the extra heat and cylinder pressures.
philippeF 04-03-2006 09:54 AM
Hello Henry Schmidt
I sent you a Pm
woud you tell me (or anybody else) if a CIS 2.7Head would fit a stock euro carrera engine ?
best regards
Philippe
