Special tools 1973 2.4S
Hi
Can anyone answer me what kind of tools I need to remove the fan on my 1973 911. I am going to glass blast the fan to give it a "new" look. Pelican number/name would be appreciated. Should i part the fan before blasting it or can I just mask out the back side (is it the alternator that is on the beck side?) Is there anything I should be especially aware of?
Thank you!
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 04-05-2006, 05:47 AM
Party Member
viejopatron's Avatar
I'll let the expert give you the tool advice.
I'd remove the fan to prepare and coat it well. Yes, the alternator is on the back (towards front of cat side).
Especially aware of? Yeah, go slow and don't break it. The cost for a fan is high.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 04-05-2006, 08:14 PM
Hi Gary
What do you meen by "coat it"? Should the fan be treated with something to keep nice or what?
Thanks for your advice!
John
Old 04-05-2006, 11:42 PM
Party Member
"coat" as in powder coat or paint. Some folks like to have the magnesium professionaly clean their fans and then apply a nice solid color. Others prefer a clear coat.
Gary
Old 04-06-2006, 04:54 PM
John,
You will probably want to do both the fan and the housing together so they will match. I have had 2 early motors rebuilt and I went with the clear coat on each because I wanted the result to look more original, which I think from reading other posts about your car, you are also interested in. Your best bet is to remove the fan and take the alternator off to blast it. Also, if the center section of your fan is still gold be sure to protect it during the bead blasting. The metal is magnesium as was mentioned so it is porous and needs to be sealed.
Here is the 2,2S motor for comparison to a painted one.
Here is a '73E motor.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 04-09-2006, 06:56 PM
Clearcoat
Hi Fryardds
Your 2.2S enige look beautifull. I will go with your advice and clearcoat it.
John
Old 04-10-2006, 01:47 AM
