-   -   Plating the Through-bolts, yes or no? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/276165-plating-through-bolts-yes-no.html)
Alan.UK 04-09-2006 02:31 AM
Hi,
I have read about how you should not plate items which are put under load, unless they are specially heated after plating process. If that is the case, I take it plating the Through-bolts is a bad idea!!
Any advice
Alan.UK
