shbop's Avatar
2.0 tnesioners and arms
I'm getting two different opinions about idler arms and what to do. Would appreciate input from those that know. I'm replacing the tensioners in my 2.0 with the spring-loaded 930 units. (Part of a complete re-build.) I've got the spacers and the fail-safe collars. What about the arms? My originals have bushings and appear to be in good shape, along with the sprockets. Is it necessary to replace these with the later model pieces? Thank you!
Jon
Old 04-11-2006, 09:10 AM
shbop's Avatar
bump
anyone been here before?
Jon
Old 04-12-2006, 07:57 AM
It is not necessary since you have the spacers but I would recommend it. You should be able to find a used set of the later arms relatively cheap.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 04-12-2006, 09:24 AM
shbop's Avatar
Thanks for the reply! What is at issue here? Is it the width of the operating surface that contacts the tensioner?
Jon
Old 04-12-2006, 09:26 AM
The theory is that the double bushing spreads the load better and reduces the chances of the arm binding. It was thought that the tensioner failures could have been caused by binding arms. Just one of those things that is relatively inexpensive and probably makes sense to upgrade while you are in there. Just my $.02
Old 04-12-2006, 09:40 AM
shbop's Avatar
Thank you!
Jon
Old 04-12-2006, 09:53 AM
