-   -   reconditioning rockers and shafts (http://forums.pelicanparts.com/911-engine-rebuilding-forum/278221-reconditioning-rockers-shafts.html)
dweymer 04-19-2006 08:27 PM
Anyone know a good shop that can do this without a long wait?
89turbocabmike 04-19-2006 08:59 PM
Ollies can usually do them on exchange/core charge.
88-diamondblue 04-19-2006 10:35 PM
Talk with John @ www.drcamshafts.com see what he has to say.
Had it right the first time Oh well.
chancecasey 04-21-2006 11:49 AM
I second the recommendation for john at www.dr-camshafts.com. Great guy. Remove your adjusting screws before sending them in. Also be prepared for some of them to break when you remove them. You can get an entire set of new ones for $50 shipped.
camgrinder 04-21-2006 04:43 PM
Thanks for the plug guys.
My website url doesnt have the - in it. :)
starlifter1 04-29-2006 09:27 AM
I did not see a price for the resurfacing? and where can you get adjusting screws for 50 shipped?
CBRacerX 05-21-2006 09:49 PM
"where can you get adjusting screws for 50 shipped?"
Ditto?
CBRacerX 05-21-2006 10:02 PM
And Camgrinder did a beautiful job on my rockers! (I'm not going to say shafts, that is too big an opening...)
Facey 05-21-2006 11:21 PM
so by exchange u mean i send the old ones, and get a different recondition ones back? like no lay over time?
because i am interested in
2 sets if the copper rings that go between the cyclinder and the block. they need to be for the 100mm p&c's.
and the second item that i require, is 6 rocker shafts, and 2 rocker arms. once again either if u can supply or point me where to go.
i have the old ones....
thanks again!
Nick
hcoles 05-22-2006 08:49 PM
Check rocker bushing wear. I made a few bushings and pressed into the rockers, then honed to fit. So far so good. I think John does this also....as I understand the original bushings aren't available any longer. I don't like the looks of the originals anyway. That's my 2 cents.
CBRacerX 05-23-2006 06:47 AM
John (Camgrinder) fits and hones new bushings, polishes faces and checks and polishes the rocker shafts.
Beautiful work done right.
camgrinder 05-23-2006 09:00 AM
Thanks for the compliment Chris!
