Cam timing specs for 83 SC Euro motor
We are just about finished the top end on my 83 Euro 9.8 motor. What should we set the cam timing at? I am running a 7:31 R/P with a tall 5th gear. I tired a search and didn't have much luck.
Thanks, |
I would use 1.4-1.7 mm. If your looking for more top end set it to 1.4mm. I assume its the original SC cam.
Yes, it is John, and thanks again. I have started packing up the x-tras. Will be contacting you in the coming weeks
| All times are GMT -8. The time now is 04:06 AM. |
