-   -   2.0 perimeter nuts? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/278611-2-0-perimeter-nuts.html)
shbop 04-21-2006 10:21 PM
2.0 perimeter nuts?
Early 2.0 case. Any problem changing the perimeter nuts to nylocks? Any torque difference? Thank you!
Henry Schmidt 04-22-2006 06:23 PM
No need for nylocks. On Porsche case they were only used in conjunction with aluminum washers.
Not a good idea with aluminum case.
You will also find the studs are too short for a functioning nylock application.
Clean the case well, use ThreeBond 1104, standard nuts and spring washers and you'll be fine.
cheers
