-   -   gasket configuration help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/278723-gasket-configuration-help.html)
shbop 04-22-2006 06:02 PM
Could someone tell me which way this goes on? Wayne's book cautions that if installed upside down there can be a serious oil leak. It can go any of 4 different ways. Thank you!http://forums.pelicanparts.com/uploa...1145754115.jpg
Henry Schmidt 04-22-2006 06:15 PM
On a 2.0 there is no wrong way.
Well you do have to get the gasket over all for studs.:)
ekessel 04-22-2006 06:16 PM
On my 964, there is a part of the case that is indented to match the extra bump on the inside of the gasket.
-Eric
90 C2
shbop 04-22-2006 06:28 PM
So, the material inside the perimeter is for another application? And just qurious Henry, do you ever use any type of sealant on this or the chain case pieces? I know the book says "no", but this block is 40 years old, and God only knows, how many re-builds. If I had nice new pieces, I wouldn't ask. Thank you!
Henry Schmidt 04-22-2006 06:42 PM
We use a thin coat of 574 Loctite.
When I say thin, I mean thin. Just make it wet.
Lay the gasket on a piece of glass and use your finger to wipe the 574 on. Then flip it and do it again.
shbop 04-22-2006 06:48 PM
Thanks Henry!
