Jk369's Avatar
Cam removal
How do I get the cam out of my 3.0? I do not want to remove the rockers or chain housing if possible. I curently have the gears off and all the rockers are loose.
Jeff
'80 SC 911
'67 Chevy SS Nova - Supercharged
'99 GSXR track only, '99 Superhawk
'05 Toy PU - daily driver
Old 04-22-2006, 01:11 PM
klaucke's Avatar
You will need to remove the rockers, otherwise there will be pressure on the cam lobes, and the rocker arms would interfere with sliding the cam out. Make sure you keep track of which rocker came from cylinder and port, because it should go back in the same spot.
Old 04-22-2006, 05:09 PM
Cams won't come out with rockers in place.
Old 04-22-2006, 09:08 PM
Nitrometano's Avatar
When you remove the rockers, I would recomend to install the RSR rocker shaft seals to prevent any oil leaks that can be in the future.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 04-26-2006, 09:46 AM
vichang4's Avatar
You might think that with the rockers loose you could maybe slide out the cam, but the cam journals will not fit past the rockers even if they are full loose.
Victor Toce
2000 Boxster S w/
Tequipment exhaust
1993 Spec Miata
87 911 turbo - sold
3.4 RUF pistons and cylinders
Euro CIS head
Old 04-29-2006, 02:54 PM
