-   -   2.0 head comparison (http://forums.pelicanparts.com/911-engine-rebuilding-forum/281228-2-0-head-comparison.html)
shbop 05-05-2006 10:46 PM
2.0 head comparison
Can anyone tell me about the 69' 2.0 T heads. Specifically if the combustion area is the same as 66' 2.0. I've recently acquired a set of 69's and I'm considering whether or not to put them on my 66' 2.0 re-build. I'm using 81mm JE's @ 9.5:1. Weber's for induction. I realize I'm not building a rocket-ship here, but the larger valve heads have me thinking. Thanks in advance for any help!
jluetjen 05-06-2006 05:03 AM
I believe (working from memory) that the '69T heads will have bigger valves then the 66 heads. These will provide a performance improvement. As far as the dome shape, I believe that it's pretty much the same.
shbop 05-06-2006 07:44 AM
John, Thanks for the reply. Do you think it's worth the effort? The ports are the same size on both:32 But the 69' has larger valves: 42/38 vs. 39/35
Henry Schmidt 05-06-2006 02:06 PM
BIGGER VALVE ARE WORTH THE EFFORT.
Go ahead and port the heads a little (35 or so) , even if they end up larger than the intake manifold.
If you still have the original 66 911 (Solex) cams they love to breath.
shbop 05-06-2006 05:03 PM
That's what I was hoping to hear. Thanks Henry!
