VE tables
Hi guys, anyone have 3.2 (or 3.0) VE tables that they would like to share for my 3.2 SS megasquirt build?
thanks Brett |
Ask tbitz, he should be able to hep you get up and running.
First the standard disclaimer. Use this information at your own risk! I'm not responsible for any damage resulting from the use or mis-use of this information.
Here are the values I'm using on my 82SC. Stock 3.0 engine and exhaust. This is a MS-1 EFI controller, injectors are 30 lbs/hr @ 3 bar, my fuel pressure is supposed to be set at 2.5 bar, but I haven't verified it. The first panel has some of the basic system configuration. http://forums.pelicanparts.com/uploa...1147211537.jpg Ok, here's the VE table I use: http://forums.pelicanparts.com/uploa...1147211799.jpg The appropriate values for a 3.2 are likely to be very different. To a certain degree, everything is based on the req_fuel parameter, which is in turn dependent on the engine displacement, desired AFR, injector capacity, and number of injections/cycle. The VE table entries represent a percentage of the req_fuel value, so if your req_fuel value is different than mine, the VE Table entries may not be valid. Hope this helps. -Mac |
MS info.
Hi Mac, Thanks for the info. Those are the first NA numbers i have seen here...
Cheers Brett |
| All times are GMT -8. The time now is 02:29 PM. |
