-   -   My '86 930 Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/281811-my-86-930-rebuild.html)
930Jim 05-09-2006 10:56 AM
My '86 930 Rebuild
Well I have read many peoples posts on their rebuilds, and now I'm starting my own, so I thought I would post some of the details.
I'm only skilled enough to be dangerous with repairs on motors, so I'm using a local shop that I've been using for several years with different cars to perform the build.
I really envy those of you who have the skill and patience to perform these rebuilds yourselves.
Anyway, here's the plan:
The car is a stock except for a B&B de-catted exhaust.
http://i34.photobucket.com/albums/d1...rontreduce.jpg
I'm converting to EFI with an Autronic SM4 setup:
http://i34.photobucket.com/albums/d1...ldautronic.jpg
Here are the other engine modifications I'm going with:
-Mahle 3.4 P&C's (long sleeve)
-964 cams
-Twin plug heads
-Stock rods to be balanced along with the uprated clutch and flywheel.
-K27HFS
-B&B I/C
-55# Siemens injectors
-GHL headers and muffler with heat
-ARP studs
I'm trying to get about 520-550 hp to the crank.
Here's my "before" pic:) :
http://i34.photobucket.com/albums/d1...otorpulled.jpg
mppickett 05-09-2006 04:47 PM
Great looking car, Jim. With that parts list you should end up with a real screamer! Good luck with the progress.
89turbocabmike 05-10-2006 09:40 PM
Nice Jim, keep us posted. I plan on using the sm4 also though my ignition system is going to have to look a bit more stock to sneak past smog;)
930Jim 05-24-2006 08:53 AM
Motor is completely apart now. Went to look at the different parts today, and I was amazed at the condition of the crank and the crankcase. The motor has 65K miles on it, but the bearings had hardly any wear at all.
http://i34.photobucket.com/albums/d1...rcrankcase.jpg
http://i34.photobucket.com/albums/d1...Motorcrank.jpg
It's interesting to see the cutouts that the factory made on the crank to balance it- now we're sending the crank and rods out for a re-balance.
The supplier of my Autronic setup has recommended I outsource my bulkhead connector and wiring harness, so I'm shopping that now. I'm trying to go with a Mil spec connector and I'm trying to order the wiring in the same color as the Autronic harness to keep confusion to a minimum.
DonE 05-24-2006 10:23 AM
Welcome to the dark side.
Are you going to keep the stock intake manifold?
Why did you pick Siemens injectors?
I think your HP expectations are realistic.
Congrats.
930Jim 05-24-2006 10:27 AM
Congrats.
Thanks. I'll be selling the stock intake manifold. I went with the Siemens b/c they were recommended to me by Stephen at IA b/c of their spray pattern. After his recommendation, I did a couple of board searches and they seem to be fairly popular. Do you know something about them that I don't?
DonE 05-24-2006 06:26 PM
Not really. I have Siemens 72lb injectors but would have gone with Bosch if they made them that big because of their low speed (drivability) control and spray pattern. Bosch 52lb inj have a great reputation in these motors at your HP level.
Who is tuning your motor?
JimCulp 05-24-2006 06:45 PM
It's a local shop called Eurospec- the owner has a great deal of experience rebuilding 911 motors and specifically many 930 motors, but this is a trial run with EFI for both of us.
adomakin 05-26-2006 02:42 PM
so you have to run two cdi's for your twin plugness? how do you split the signal?
JimCulp 05-27-2006 02:45 PM
I'll let you know when I find out.
klein930 05-31-2006 08:09 AM
Let us know how your wiring harness turns out. I need to send my EFI harness out due to poor job.
JimCulp 08-25-2006 11:37 AM
Finally some (albeit minor) progress. I got the powdercoated pieces back today. The turbo housings, intake manifold and heads are back from Extrude Hone. We are doing a five way grind on Monday/Tuesday and everything should be ready for re-assembly.
http://i34.photobucket.com/albums/d1...angereduce.jpg
magic930 08-26-2006 08:10 AM
Stock Intake with custom blocks and rails or 3.2 manifold?
JimCulp 08-27-2006 05:59 AM
993 fuel rail and blocks.
930Jim 09-01-2006 05:44 AM
The heads are back and ready for assembly. They had the Extrude Hone process done, a five angle grind, new valves/springs/retainers.
http://i34.photobucket.com/albums/d1...vesreduced.jpg
http://i34.photobucket.com/albums/d1...ngsreduced.jpg
http://i34.photobucket.com/albums/d1...iewreduced.jpg
Assembly to start next week.
